Old 01-23-2015, 11:47 PM
Originally Posted by Zenith6S321 View Post
At the moment mine is still intact. Is there some way to visibly see that it is crystalized? On other sets where the ferrite cores have been tight, I have let them soak in a little WD40 which seemed to ease their movement. Any suggestions for this coil?
From the photo, it looks like the coil form is phenolic. If so, you're in luck. The whitish, semi-clear plastic forms are the ones that crystalize.
If the three blue adjustment coils on the convergance board also have phenolic forms, you're doubly in luck.
