Old 01-28-2015, 06:17 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
I finished replacing all of the electrolytics. I removed all of the connections from the old electrolytics and mounted the new ones on the underside of the chassis. For now I have wired the caps as per the Sams schematic. The Zenith manual I ordered should be here in a day or two and I will compare the schematics.
I also checked the diodes and found a problem with the three section convergence diode. Two of the diodes read like a silicon diode. The third is shorted. Can I just use three 1n4007s for these? I think I read to use Schottky diodes but I don't know what current or PIV should be. A suggested part number would be great if anyone has had success with it.
Dave
