Sony 5-303W
Hi:
I picked up a nice little Sony 5-303W with the case, cords and operating instructions. I have changed out the all of the electrolytic caps and it now works really good except for one little problem, I cant centre it on the horizontal. Its about half an inch, which is a lot on this little crt, to the right of centre and if I try to adjust it I get these strange looking bars across the top and if I keep going it loses lock. Other than that the picture and sound are perfect. Any ideas or does anyone have any service data on this set? Thanks Gregb |
IIRC, there are a couple of rings at the rear of the yoke that are rotated to position the raster.
Edit add: Rotate the two rings *together* to move the raster up/down/left/right... Rotate one ring *relative* to the other to change the amount of position shift that is obtained when rotating both together. jr Last edited by jr_tech; 02-14-2015 at 05:27 PM. Reason: add info |
I will have a look, Thanks jr
Gregb |
