Old 01-14-2016, 02:05 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Here's an updated picture of the set back together and on. Fm radio comes in great, but still no picture. Still trying to trace down why...?
Old 01-14-2016, 03:29 PM
Finally got a raster!! I found a 16.5 watt, 2450 ohm bleeder resistor on top of the horizontal output chassis. It was completely open and fed the oscillator circuit, along with the 1B3s. I had a ignite 50 watt adjustable power resistor that I was able to get pretty close. There's still a lot of adjustments to make and it's not as bright as it should be, but finally some encouraging progress!!
Old 01-14-2016, 07:04 PM
After playing with the horizontal frequency, I've got a picture. Getting the horizontal to hold for more than 3 seconds is what I'm battling right now.
Old 01-14-2016, 10:50 PM
kvflyer kvflyer is offline
Looking much better, congratulations! Now, you can pick at the remaining problems one at a time. Good luck.
Old 01-15-2016, 11:16 PM
Forgot I had this original ad. It will be nice displayed next to it and wow, $795!
Old 01-17-2016, 06:35 PM
I'm going to order mica caps for the horizontal hold circuit, should I order ones at 1,2 or 5% tolerance?
Old 01-17-2016, 08:03 PM
What is the tolerance of the originals? As a general rule of thumb order the same or lower tolerance (i.e. if the original is a 10% order a 10% or a 5%, but never* a %20).
*Unless you have high accuracy measuring equipment and you can buy a bunch of sloppy tolerance parts to cull a good one from cheaper than the correct tolerance part.
