Old 10-19-2017, 10:16 AM
Does this set use an SCR for horz output ?
Or separate HV & sweep outputs ?
Or just one transistor ?
If SCR usually it shorts & blows the power supply. VERY
hard to fix, either bad drive or load in the HV. If you
dont find everything thats bad will blow again.
Cant help with circuit, schematic too blurry.
The KV1212 uses the 2SC267 transistors in the HV sweep circuits.
The circuit is a little tricky and it used selected components. You generally had to use genuine Sony replacements which were hard to get, even years ago. They generally failed when the horiz driver transformer connections needed resoldering.
They also used those transistors in the power supply.
