Curtis Mathes Console Schematic
I recently picked up a 1963 Curtis Mathes console model AG2A23, and need a schematic for it but can't find it listed on SAMS. Does anyone know whether it goes by another model number? The only number on the chassis is 168153 which is engraved in it. Below are a couple of pictures.
https://www.curtis-mathes.com/apps/p...toid=117223300 https://ufdc.ufl.edu/UF00028307/00771/10j Thanks in advance. |
Looking at the CM ad I got to wondering exactly what a “color convertible” is. The price seems too low to be a true color set. Also, I don’t know of any 24” color CRT.
Mine's a 23-inch black & white. I did a little research, and back then Curtis Mathes was using RCA chassis in their consoles. Still the only number on the chassis that I have is the engraved number which doesn't correspond to anything that I can find.
It was mostly marketing. The deal was if you go ahead and buy the black and white model, it could be updated later to a color set. There was a conversion where you would remove the old chassis, face plate and CRT. Then replace it with a new color CRT, face plate, and chassis. I have never seen one that was converted, but I'm sure someone likely did it. Given the reliability of our CM set of the time, it would have been better to just buy a new color set and be done with it.
For manual you need a Sams collection. Go through all CM sets
from the apx date built for say 2 yrs. Wont be very many. You should find one close. If its a real RCA & they used there chassis number the format is KCS-###. Also post a few chassis pictures & maybe we can ID it. 73 Zeno ![]() LFOD ! |
Their earlier color sets were RCA chassis. Some B/W chassis, the radio P/S was part of the TV chassis. The radio had it's own P/S in the better models. |
I told them, yes and no! The B/W chassis would have to be gutted and maybe a 22" Zenith table model could be fitted. The 22" Zenith had lousy CRT's.
