Old 03-10-2024, 08:29 PM
pac.attack76's Avatar
Stuck in the past
1988 Emerson 19" model ECR2100D dead
Set powered on as soon as I plugged in. Started up and showed digital channel display and screen lit up with the usual static. Ran for about 10 seconds and shut off on its own. I then unplugged it and heard a relay. Since then, nothing.
Genesis does what Nintendon't
Old 03-10-2024, 09:04 PM
Doug Doug is offline
Maybe bad regulator.
I would try on variac maybe 90v in ch b+.
I assume safety circuit shut it down
Old 03-10-2024, 09:19 PM
Stuck in the past
I don't have a variac.
Old 03-10-2024, 09:45 PM
I find good buys at fleamarkets at hamfests
I find one coming up in your state maybe more
https://www.arrl.org/hamfests/search
Sometimes on shopgoodwill.com you can find good deals. If its at your local hub
U could pu locally save shipping
Old 03-10-2024, 10:23 PM
Stuck in the past
Alright. Is there a way to test regulator and where's it located?
Old 03-11-2024, 06:12 AM
Normally the regulator is at the mains wiring input, after fuse, diodes and big cap for filtering; then it follows to regulator. It drives an transformer or a inductor (if it is a SMPS; probably due to age of this TV). THe main regulator for sure will have a heatsink.
For testing it, is not advised to isolate them from load; most old SMPS explodes without load.
Old 03-11-2024, 08:15 AM
Look for a 100 k ohm IIRC off the B+ adjust pot.
Would restart but randomly go HVSD. A $1 test !
Zeno
Old 03-11-2024, 10:14 AM
Stuck in the past
Zeno
I'll look and get back to you.
Old 03-15-2024, 11:21 PM
liammc00's Avatar
liammc00 liammc00 is offline
real TVs have a CRT
I was always afraid to put a solid state on variac as I was told it could damage the set. Also my variac is modern one I got off Amazon its not the best but it works.
