Old 06-26-2007, 11:03 AM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Originally Posted by compucat View Post
That's wasteful. I won't buy I set I can't service. I wonder how serviceable the typical LCD set is going to be.
Ive actually replaced a backlight on an LCD panel that took a spill off a table before. Most computer stores sell cold cathode lamps that gamers use to illuminate their fancy computer cases. These lamps are pretty similar ones to the ones used in the backlights of LCD panels. All i did is remove the fragile glass lamp from the colored plastic tube and solder it to the inverter board. Once I put it back together, you couldn't tell the difference.
http://microcenter.com/single_produc...uct_id=0248872
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
