  #39
Old 08-19-2007, 05:01 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Cool
Finished the B&K Analyzer. Two small 10V electrolytics on the audio-osc PCB were open too. Once replaced, the 400Hz tone is present. Actually it's at 438Hz according to my frequency counter, but for now, close enough. I'm sure there's a trimmer under there, later.
Shown working on the Admiral from Hell. Unfortunately I was mistaken, the only audio-only signals from the B&K are straight 400Hz tone, or 400 Hz tone FM-modulated at 4.5MHz. Not terribly useful for split-sound audio problems. I did inject the 4.5MHz onto either of the cathodes of the 6al5 FM discriminator, and it discriminated (i.e. I heard a pretty reasonable 400Hz (I mean 438Hz) tone at a reasonable volume).
Injecting the 4.5Mhz signal at the grids of either sound-IF 6au6 amp yielded nothing (no sound). Not sure if it would or not though, even on a working set.
In IF mode, I injected at the grid of the first 6au6 and swept up the range. There were a few places where I was able to get tone out the speaker, but not at great volume (muffled and far away, like my original "tune it by eyeball" results of some weeks ago). One point in the sweep yielded that very loud poppy 60-Hz buzz that all TVs make when you tune the fine tuning too far right. That was the only full audio level I've ever heard out of the set (other than injecting transistor radio directly into the first audio amp).
I've ruled out the LO being off, ruled out the discriminator not discriminating, and ruled out the audio amp itself. Have ruled out any power-supply issues (all plates in the sound-IF strip are at voltage spec). Have ruled out all resistors (they ohm out to spec). Have replaced all paper caps in the strip with orange drops. Have double-replaced the sound-IF tubes, have ruled them out. Leaves very little. Those caps that are buried in the IF transformers, maybe. Or the IF transformers themselves (windings shorted maybe, not open, because they ohm out ok).
The B&K is a pretty cool tool though, and will be indispensible later on other projects, I'm sure. After I toss this freekin Admiral in a dumpster.
