Old 05-22-2008, 02:20 PM
Dan Starnes's Avatar
Gizmo Nut
Well that was easy. Got inside the back of the set and setout to just look at all the horizontal related tubes. First tube I touched was the Horizontal output tube. When I removed it and tried to remove the lead to the top of the tube the metal that the lead clips to fell off. Replaced that tube with a known good tube, gave set a good dusting inside and turned it on. Now works fine, also did a minor centering adjustment via the magnet on the yoke.
Again thankyou for your input, I am learning from this site, as well as the links you all lead me to.
Dan
