Awesome reception on my digital converter
I live out in the country, but I am out near the transmitters where the stations broadcast, same old places since the 1950's. For VHF and UHF I needed rabbit ears. Tonite I was changing from VCR to digital converter. I have everything tied into a set of rabbit ears, whether it be UHF, VHF, or digital. 3 sets tied into all that. When into the VCR for feed it needs adjustmant on the rabbit ears, but the digital feed does not need any adjustmant and all stations are clear. My question is, are the digital stations broadcasting a stronger signal?
Dan |
Probably not, but because of its nature, you won't see ghosting or fuzziness. Check your signal strength meter. If it's below 60%, you risk the channel dropping out.
power, the ratio between the direct signal and the multipath (the delayed signal that causes ghosting) remains the same, and you still have a ghost. Signal processing that involves error correction ensures that you either get a very good image or no reception at all (if signal is too weak) with digital stations. |
![]() Are you kidding me?! 60%? My God, I'm lucky if I get any signal levels above 40%, and one of the transmitters is just 4 miles from my house. I'm using an amplified outdoor antenna with a rotator, too! The only time I get channels dropping out is when the level drops below 15% (which is pretty often with any channels more than 20 miles away now that all the trees are in full leaf). Sheesh! Tom
Tom |
My experience with my HDTV card's signal strength meter tells me that ~60% is approaching the danger zone. If the wind kicks up, or it rains, the signal will be in danger of dropping out. Maybe convertor boxes can handle weak signals better... And you either live in extremely hilly terrain, your antenna setup is malfunctioning, or you have a f***ed up convertor box. i suspect your amplifier, since some of those don't work well with digital signals. |
The converter boxes may be able to handle weak signals better than the PC cards; but I don't know if the box needs a stronger signal than the card. The boxes only produce 480i video from what I understand, whereas the cards are designed for true HD reception. My thought would be that the card requires a stronger (more complete?) signal from the transmitter to produce a watchable picture whereas the converter box doesn't since it only has to produce a picture good enough to feed an analog set. Anybody have an expert opinion?
That said, I am getting a far better picture with digital than I ever could here with analog, and using a much smaller antenna. Oddly enough, I do miss all the artifacts I've grown up with, such as airplane flutter and lightning noise in the picture. Maybe I'm just weird. -Jim Last edited by N9ZQA; 06-22-2008 at 11:39 AM. Reason: 480p to 480i - it was late! |
Tom
Tom |
Still doesn't fully explain it, as I live a good 25-30 miles from some local stations, and I can get them at full strength if the antenna is pointed in the right direction. |
I'm very surprised as I read this... I use only a bowtie indoor antenna and I get great reception (85-90%) at all times... I'm about 25 miles from the transmitters too. Maybe its due to my second-story location?
