Old 12-05-2008, 12:25 AM
At least when they have a line, that means they also have HV.
Old 12-05-2008, 07:02 AM
Yep, ditto on that, just be careful not to burn your phosphor with the line. Turn the brightness all the way down. Check your service switch for an intermittent. Otherwise probably a simple vertical problem like a failed cap or something. Good luck getting it going.
