Old 02-27-2009, 04:40 PM
Tube FM front ends tend to go bad easily, if the tube gets a little low on emissions. Also many such AM/FM sets tended to spend most of their life on AM, and the FM tube would go bad due to "sleeping sickness" (the cathodes being hot but no current being drawn does bad things, but a few tens of microamps of current is enough to prevent that, connect a 100K or so resistor across the B+ part of the band switch on such an all tube radio, not this one though). But the transistors won't have this issue. But transistor FM RF front ends did suffer easily from signal overload, intermod products creating interference on weaker FM stations (though I've been told that increasing the current thru the RF transistor will help). Living 14 miles line of sight from NYC's Empire State Building's FM broadcast antenna farm brought this issue firmly in my face... Tube front ends usually did better on this.
Tube line up is probably like that in an AA6 AM radio, but the extra 12BA6 being the 2nd FM IF tube (and it may be a 12AU6). If they were skillful enough, they might have been able to put that 2nd FM IF tube to work as an AM RF stage, like in most AA6's.
Not using a tube FM front end meant that they would have enough heater string voltage left to use a 35W4 rectifier. Which might have been cheaper at the time than a SS rectifier diode.
GE used the same or quite similar audio output transformers in their solid state hot chassis radios as well.
Old 02-28-2009, 07:42 PM
nasadowsk's Avatar
Damn does run fast…
Looks like typical GE build quality...
Old 03-01-2009, 12:01 PM
Reece's Avatar
Reece Reece is offline
It's a nice clock radio, well preserved, too, and does what it's supposed to do. But consider the power of advertising: it proudly announces "Dual Speakers." Wow, that must be better than a radio with one speaker. It's kind of like a stereo, isn't it? Let's buy this one. Bingo.
The fact that one or two or three or six 4" speakers still sound like...guess what? a four-inch speaker, with the same frequency response, does not matter.
G.E engineers knew that in that same size case they could have got one 4 x 6" or even one 5 x 7" speaker and had much better sound, with a little inkling of bass, but with the clock moved over to one side of the front, and maybe for the same cost, but then they couldn't have advertised Dual Speakers! The Advertising/Marketing Department won out, as they usually do.
Then again, I'm sure 4" speakers were churned out in greater numbers than any other size, and cost next to nothing. So the Bean Counters had the last word, too.
Just some observations on manufacturing.
Reece
Reece
