  #32
Old 03-15-2009, 10:41 PM
colorfixer's Avatar
You'll likely need to use a solvent like varsol to wash the old grease from the mechanism, or at least soften it up enough to be able to free the mechanism, enough to even temporarily allow the machine to play.
You could also have the seized grease in bearings which would cause the mechanism not to run smoothly, or throwing the alignment off.
