Old 03-19-2009, 09:38 PM
Conchord Conchord is offline
AK Member
Originally Posted by gadget73 View Post
277v comes from running one leg of a 460v 3 phase supply to ground. Nothing special about it. Lighting in industrial complexes is commonly 277v single phase, since its really simple to make that from the 460v 3ph mains. Where I work, we have 460v 3ph supplies, 277v lights in the warehouse, and a few 240 and 120v systems as well. We get our 240 and 120 from a couple of big step-down transformers installed throughout the building.
Its 480v, not 460v. There is certainly nothing special about it. 277V single phase is not a commonly used term, 480 single phase is however. While it may be a misnomer, this is what they're called: 277 or 480 single phase for a hot/neutral or two hots respectively.
Old 03-19-2009, 11:35 PM
zane zane is offline
VK Member
Thanks for the cap info Gadget, I do have a lil supply here somewhere
I can dig thru, might get lucky.
There are so many combinations of voltages(delta, Y, high legs),
that could turn into a looong discussion. Regions...
The newest thing comercially is clean computer power, 200% neutrals, isolated grounds.
Tons of money wasted, there's a transformer in every computer, there is your clean power. A surge suppression power strip and you are good, sometimes I wish they realized that, but then again a paycheck is nice too.
