The second one I bought sounds better, amazing, impressive, perfect, static free and has noticeably better sensitivity than the first. It also has a shot a tuning-dial cords. I feel like the recap on the first will bring it up to specs. Amazing the tweeters work on both, which I am thrilled with. They both need to have the tuning/dial re-strung. The strings are gone or barely there. I did some very subtle lube of the shaft, pulley and air-cap. What a difference. They both will get be recapped. I am about to place an order for a slug of filters and electrolytic caps. Although my first overhaul of old tube radios, I feel confident after study of the schematics (for a few hours looking the the bottom of the chassis). One had the selenium diode bypassed. I think they one they used was a 1N4004 which is good enough, but the solder is kind of crude and want to put some insulation on the leads to class it up. I'll go to 1N4007. I might up the 22ohm 1W diode down stream but don't think it needs it. Since the DC does not drive the filament heaters on the Y832 I don't think the voltage is as critical. When going from selenium to silicon the voltage drop is less, so a drop down resistor is added. The plate voltage is 100-250 volts. I don't think a few more volts will kill the tubes, since line voltage is 117VAC. (WHAT DO YOU THINK?) Thanks for the INFO! Cool stuff. Last edited by gmcjetpilot; 07-31-2009 at 01:06 AM. |
