Schematic
Here is the schematic again, hope you can open it this way.
This is a battery operated radio, using two different batteries, so the question of it being a live chassis is not applicable. The batteries do not share a common ground, so you must make sure the battery eliminator you use is compatible with this fact. Regards. |
