I believe someone put this radio chassis into an older cabinet. The dial is off center in the cabinet top. There is (what appears to be?) a large speaker grille on one side and what looks like a dial bezel on the other which doesn't make any sense. If your bandswitch has three positions, one might be for a phonograph: trace the wiring and perhaps the plug hanging off the back is AC for the phono motor, and one of the jacks is for phono input. The radio has a loop antenna for AM, but for FM would probably, in that era, need an external antenna so there should be some terminals for that.
Reece
