Old 11-11-2009, 11:10 PM
Findm-Keepm's Avatar
Followin' the Rules...
UPDATED in February to include the Digital Transistion - you'll need to check out 47 CFR, FCC Part 15.701:
This subpart sets out the regulations for Television Band Devices (TVBDs) which are unlicensed intentional radiators operating on available channels in the broadcast television frequency bands at 54–60 MHz, 76–88 MHz, 174–216 MHz, 470–608 MHz and 614–698 MHz bands.
(a) Power limits for TVBDs are as follows: (1) For fixed TVBDs, the maximum conducted output power over the TV channel of operation shall not exceed one watt. Transmitter power will be measured at the antenna input to account for any cable losses between the transmitter and the antenna. If transmitting antennas of directional gain greater than 6 dBi are used, the maximum conducted output power shall be reduced by the amount in dB that the directional gain of the antenna exceeds 6 dBi.
(2) For personal/portable TVBDs, the maximum conducted output power over the TV channel of operation shall not exceed 100 milliwatts; except that for personal/portable TVBDs that do not meet the adjacent channel separation requirements in §15.712(a), the maximum conducted output power shall not exceed 40 milliwatts. If transmitting antennas of directional gain greater than 0 dBi are used, the maximum conducted output power shall be reduced by the amount in dB that the directional gain of the antenna exceeds 0 dBi.
(3) TVBDs shall incorporate transmit power control to limit their operating power to the minimum necessary for successful communication. Applicants for certification shall include a description of a device's transmit power control feature mechanism.
(4) Maximum conducted output power is the total transmit power in the entire emission bandwidth delivered to all antennas and antenna elements averaged across all symbols in the signaling alphabet when the transmitter is operating at its maximum power control level. Power must be summed across all antennas and antenna elements. The average must not include any time intervals during which the transmitter is off or is transmitting at a reduced power level. If multiple modes of operation are possible ( e.g. , alternative modulation methods), the maximum conducted output power is the highest total transmit power occurring in any mode.
(b) Antenna requirements . (1) For personal/portable TVBDs, the antenna shall be permanently attached.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
