Old 05-04-2010, 09:47 AM
Originally Posted by PredictaNoob View Post
Here is the chassis after I cleaned it with q-tips and alcohol (a technique I learned from here!). I tested the resistors and found 20 of them on the board and tuner that were out of tolerance! I've been attacking the rust, but still have a few places to address while I wait on the replacement parts to arrive.
something about that pot on the extrerm right does not look right, Although the mounting arangement seems correct for the type of pot used. Odd. just a guess but the resistor is prob a higher than called for value and the pot is lower than called for. that way less voltage drop across the pot so a lower wattage pot would work (but the range would suffer as well so the fixed resistor would have to be pretty close to the correct total required value).
