Old 07-09-2010, 09:37 PM
miniman82's Avatar
First Light: 1952-2011
In the CTC-5 , it's a DC control, which unfortunately runs the brightness up and down along with the contrast because the cathode (and plate) current is not zero at black. Several people with CTC-5's have modified their sets to be like your CTC-7 to fix that problem, but it reduces the DC coupling
Um, I have a CTC-9....
Keep looking and I will too -it's around here (or maybe audiokarma?) somewhere. The brightness could still work if it changes the height of the blanking interval and you end up clamping to the bottom of that - but not sure if that is the case.
Will do!
