Variacs and possible alternatives
I was just thinking about this last night, variacs seem to be really expensive.
Just thought I'd compile my thoughts, maybe helpful for someone. So, where would be a good place to find a cheap one. I found one on ebay that I might just get, but for the time being is there anything I might have around the house that would work? Well, there's the dim bulb tester which kinda does the same thing. You would just need varying wattages of light bulbs, possibly some big resistors mounted in light bulb sockets. I almost want to make something like this and include a dimmer switch for greater control. Well, why not just use a straight dimmer switch? I guess the simple answer to this is it just isn't the same. It uses a variable resistor instead of an autotransformer. It also wouldn't be able to handle a lot of amperage. But, I really don't know on that one. The other idea I thought up, is why not find where the plate voltage from a tube tester goes, and tap into that? On my tube tester at least, it goes from 0 to 100 volts with some fairly accurate indicators along the way. Well, tube testers seem to be more expensive than variacs and I really don't want to fry it. I'd imagine they're not meant to take a whole lot of amperage on the plate voltage circuits. With the way my tube tester specifically is made, I don't think its designed to take much amperage in any situation. The control for the plate voltage also seems to be a dimmer switch and not an autotransformer. So, I'm not sure. I'm gonna watch that one and see what comes of it. What would you guys recommend and what do you use? |
I have a Tenma 72-1097, which is a variac & isolation transformer rated at 3.5 amps (yet it's fused for 6 amps.) I had a lower amp B&K but one side of the transformer went open - I think the variac part is still good.
The way you can think of a light dimmer is that it cuts up juice into longer or shorter pieces with blank spaces in between, longer pieces for brighter light, etc. The result is OK for an incandescant bulb but would be a buzzy mess for electronic work, and there's the power handling problem.
If you look around you could find a variac at a flea market. I got a good one in a metal case with pilot light, switch, and voltmeter for five bucks. Your best bet until then would be the dim bulb tester. It protects as well as cuts voltage (bright light tells you to shut it down, now!) Some have used a three-way bulb, like 30/70/100 with three-way socket, of course. In that case you need to mark the switch so you know which position you're in. A bit more elegant would be made up of three or so sockets and switches with maybe 50, 75, and 100 watt bulbs; larger for larger TV's. You don't really use a variac much, usually just on first startup, so a simple one socket deal and a handful of bulbs (just change 'em to go up in voltage) is really sufficient. Edit: I just looked at that auction you mention: that would be great. Mount in a metal box, switch, pilot light, receptacle, fuse, nice little project. Go for it!
Reece Perfection is hard to reach with a screwdriver. Last edited by Reece; 07-23-2010 at 09:53 AM. Reason: Added auction mention. |
I second everything Reece said
![]() I use a vintage RCA ISO-TAP WP-25A isolation transformer and a modern variac from Circuit Specialists. |
PM me - I have a hefty powerstat (~10 Amps, IIRC) that's yours for shipping (USPS parcel or Priority Large F/rate) - it's still in the metal box someone mounted it in at NASA Langley years ago. I use a 22 Ampere Powerstat I got from NASA, fused at 7.5A for power on testing, and I can change the fuses to fit my needed safety margin. Massive monster for sure! Cheers,
The one I'm offering is a 116BU, same as this eBay item: 150258319426
PM me and it's yours for shipping. Cheers,
What does the isolation transformer do? I know I've seen them and I have an idea as to what they do, but I've never been too sure. PM sent. |
An isolation transformer will make the set act as if it had a power transformer. Summary - increase your odds of survival
Ah, so its basically a transformer that takes 120 volts in and puts 120 volts out.
The "poor man's" isolation transformer can be made by stacking two high-current transformers back-to back. Years ago, I made one with two 50V transformers I got from old 48V telephone system supplies. I just wired the secondaries together, and used the primaries as in and out. Mine was probably good for only a few hundred VA.
Here's a cool youtube video describing the same: http://www.youtube.com/watch?v=QDSmv9E5VgQ Cheers,
I'm thinking two MOTs wired like that would work, those handle a few amps normally.
I've rewound only one MOT - I used it for a high current supply before I found a battery charger that had a more capable (heftier) transformer. RCA Isotaps and B&K isolation transformers use to go cheap on fleabay at auction, but now most are fixed price - BIN sales, so the bargains went away. I got a Sencore PR57 off eBay for cheap and promptly resold it. I wish now I'd kept it! Cheers,
Cool, just got Findm-Keepm's variac today.
It's a bit of an odd piece. The scale on it goes from 0 to 120, but the wiring diagram shows that it's set up to go to 140. So, there's pencil marks around it at voltages that must have been important at one time. So, I think I'm just gonna put a volt meter in the case along with a cord connector from a computer power supply (I have plenty of those to scavenge) and a power outlet. It was lovely how the power cord crumbled away in my hand... Last edited by danrulz98; 07-30-2010 at 03:14 AM. |
I tend to search locally for odd stuff - I use fleaybay, Public Surplus, and rarely, CL. About a third of my test equipment came this way - cheap too. My big ol' variac that would have set me back over 360 bucks cost me nothing after I sold off other stuff I got in the lot of equipment. Frugal, yes, but fun for sure! Cheers,
