Old 08-24-2010, 04:08 PM
rca2000's Avatar
rca2000 rca2000 is offline
Originally Posted by Dinkar View Post
I have tried in fairly dark room, off light, as is the B-W.
It has been a few years since I "played" with my VF...but I am SURE that if the photocells are NOT positioned correctly in front of the screen you will not have color. I recall that if ONE of the cells was covered--you would get a "weird" picture, with "confetti" all through it or such--and if BOTH cells were blocked--the color was gone and a "somewhat " BW picture was the result.
That color VF was a -neat idea...fun to play with... but it is NOT really practical to use out of the case--since the index stripes are picked up on the OUTSIDE of the tube--and ANY external light will "mess things up". On the Sony vidimagic, the index info is picked up on the REAR of the tube and from a DIFFERENT phospor--that glows a bright green--from the rear of the screen!!
