Old 10-30-2010, 07:42 PM
Thumbs up What vintage TV do you have the World Series on?
My Admiral TV, with 3 converter boxes, two of which modified to output B&W only on channel 2 and channel 5. The 3rd is an unmodified Zenith.
Old 10-31-2010, 08:08 PM
Not a huge bezboll fan, but it's an excuse to exercise this one for the first time in a few years.
Phil Nelson
Old 11-01-2010, 09:27 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Do not attempt to adjust your set.
Old 11-01-2010, 09:35 PM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
Hey wa2ise, I was just curious about your converter box setup. You said you have two modified to output B&W only. Since your set is already B&W, I figured you must have a good reason for this arrangement. Does sending B&W only signals to your set rather than color signals improve it's performance?
Old 11-02-2010, 05:34 PM
This older B&W set was made before color TV was deployed. So this TV set will provide the full resolution of the NTSC picture, including the color subcarrier. The subcarrier looks like a fine pitch checkerboard pattern slowly crawling up the screen. Later B&W sets low passed filtered the luma to supress the subcarrier. So I turned off the subcarrier at the source, to avoid the crawling checkerboard. The two boxes are the CM7000 by Channel master. Briefly, the mod:
