Old 01-17-2011, 11:48 AM
Originally Posted by jpdylon View Post
I'm slowly restoring that same set. Mine has a slightly different CRT mask and with a BFP and separate safety glass. Should be a looker when its done. The 9 through 11 make damn fine pictures when tweaked out.
That’s great to know there is another set like this in the works. Do you have any pictures of the set, or your restore to date?
I have no intention of breaking the safety glass off this CRT… there must be a better way. Time is no concern, so if a slow soak in some solution would work, that would seem a much better option. Last thing I want is glass shards all over the place. My wife would about disown me at that point. Not to mention I’d have a hard time living with myself if I ended up hurting someone in the process.
I’m a total newbie to working on a color set (have only restored two b&w sets to date), so I’ll be proceeding with extreme caution. I do have plenty of tube radio and audio experience under my belt, but this is a whole new adventure.
Thanks for all the comments and suggestions, I’m enjoying just having this set in my possession for the time being.
Kevin
