You need a device that can output RF modulated video on channels 2-13.
Most VCRs can do 3 or 4. The LCG-388 should be usable too. You may also need a 75-300 balun to convert from a 75 ohm coax type connector to the 300 ohm antenna spade terminals on the 802. |
