Old 01-18-2011, 02:21 PM
stusnyder's Avatar
Well I figured out the leader...tried it on a old tv that I had that that still works.
Anyway I did check for stuff touching, shorts, ect. Since it does the same thing as before the recap, that tells me other components. I guess checking resistors are next, although there are a number of "domino dot" caps in the unit. Found a weak 1b3 tube and put in a good one, but same results
