something new I have noticed, when 1st turned on I get a mostly green screen, 15 sec later the screen is all correct. I assume its just the green gun is stronger than the others. I suppose I could try it on another CRT and see if it does the same thing. or maybe just use the CRT tester note the full emissions time on each gun after allowing it to cool off between test.
