You should be able to find a 12LP4 CRT to put in the set instead of a radar tube, which is most inappropriate due to the long persistence phosphor. As you likely know, 12LP4 CRTs are rather common over here in the US, and come up on ebay regularly. You could ship one to AU for a reasonable sum.
Good luck with the Andrea, they made a very high quality set.
John Folsom |
