Old 03-30-2012, 03:45 PM
Clear Cast HDTV antenna tests -- update
Greetings.
I received my new ClearCast HDTV antenna the other day. I was able to receive a few stations but, unfortunately, the two channels I was hoping to receive (Cleveland channels 8 and 19, the subchannels of which are 8.2, Antenna TV and 19.2, MeTV respectively) did not show up on my flat screen in several channel scans. Here is a list, however, of the channels I do receive with the Clear Cast at my location 30+ miles east of Cleveland, near Lake Erie:
1a WKYC, NBC, Cleveland ch. 3.1
1b WKYC Weather Radar
2a WEWS,ABC, Cleveland ch. 5.1
2b LiveWell Network..........ch. 5.2
3a WVIZ, PBS, Cleveland....ch. 25.1
3b WVIZ Ohio channel, ch. 25.2
3c WVIZ World, channel 25.3
3d WVIZ Create, channel 25.4
4 WBNX, Akron-Cleveland, ch. 55.1
5 CSCN, audio only, channel 38.9
I receive several other channels besides those listed, but the other channels are duplicates of the listed stations (and WBNX's standard-definition and This-TV subchannels); I don't know why the ClearCast picked up the local stations twice.
I do not know what the CSCN channel is supposed to be, as I did not listen to it very long; however, I suspect it may be an LPTV (low power TV) station since it carries audio only, perhaps from a local FM station, such as are found in the Chicago and New York City areas. These cities have LPTVs on channel 6 (as I learned from reading posts by VK members living in those areas) which can still be received via an antenna, but for how much longer is anyone's guess.
I tried the ClearCast antenna at many different spots around my apartment (as many as the length of the supplied antenna coax [about 15-20 feet] would allow me to get to) but, try as I might and did, I could not receive channels 8 or 19 at all -- not even a pixelated image.
I don't know whether these two channels (eight and 19) are in locations that just do not allow the signals to reach this far east of town without a real outdoor antenna or what the problem is, so I went back to cable and stored the Clear Cast antenna -- for now, anyway.
Do not waste your money on the Clear Cast antenna, as it is little more than a repackaged version of the old UHF bow-tie indoor TV antennas that used to come with new televisions 40+ years ago (and were available from Radio Shack, et al.), long before DTV -- and the CC antenna works just about as well as those bowtie aerials did, which wasn't very well in anything other than strong to moderate television signal areas. The Clear Cast does receive UHF DTV stations well, but if the DTV channels in your area are still on VHF channel positions (as are 8 and 19 in my area), it will not work well since the CC is not designed to receive VHF channel frequencies. WOIO-DT is a translator station for Cleveland CBS affiliate WOIO, but unfortunately the translator, on channel 24, is in the Akron, Ohio area (it is meant to cover that area until WOIO's antenna work and power increase are complete) and does not reach here.
My best advice is to get your indoor DTV antenna (if you decide to use one instead of a rooftop antenna) from Best Buy, Radio Shack, et al., as the DTV antennas these stores carry are better and much cheaper than the ClearCast; the CC antenna costs $38 plus shipping (for whatever reason, mine cost almost $60 with these charges included) if purchased directly from its manufacturer, Brilliant Built Technologies of Canton, Ohio, 70 miles southwest of Cleveland.
