Here are the 6DR7 resistance readings.
1: 406 ohms (measured from 275V B+ source) 2: 1.97 megohms 3: 1.97 megohms 4: .1 ohm 5: zero 6: 1.68 megohms (measured from 275V B+ source) 7: 67.3 K ohms 8: 51 K ohms 9: 217 ohms The resistance on 6, 8 and 9 varies with control settings. The R63 thermistor is behind the yoke. I shorted it out with a jumper and tried the set. No change in height. Phil Nelson ![]()
