Old 06-04-2012, 08:34 PM
stromberg6's Avatar
Originally Posted by miniman82 View Post
There are only 2 possibly fixes for the shroud:
If you have the pieces, glue/weld them back together.
Find a better one.
I like option 2 the best, since once it's broken it will never be strong again.
Thanks Nick. I believe option two will be the best way to go, as I don't have the missing pieces. I've thought about sanding off the aquadag around the breaks, and building up the areas with something like Bondo, than applying corona dope all around the compromised areas to suppress arcing, but the more I think about that approach, the more I hesitate. Well, nothing ventured, nothing gained, so I'll try to repair the shroud before using a 21CY.
Kevin
stromberg6
