Old 09-10-2012, 04:15 PM
jpmad4it jpmad4it is offline
Originally Posted by colorfixer View Post
Try putting the composite video from the N64 onto the composite video in pin on the monitor for the sync.
The sync from the modded N64 is composite, and the monitor expects separate v and h sync on the designated pins but should happily sync from the composite in. This was done, as was said before, to accomodate teletext and overlay.
Also, make sure they put 220uf 16V caps on the RGB lines inside the N64 since there is a 5v bias on all three which will harm the input circuitry on the monitor. I have a SNES and N64 both happily running on a KX1901, but the north american version doesn't have a SCART connector, rather a header connector that was a monster to work with.
If this doesn't work, you'll need a sync separator such as an LM1881 which is simple to build up.
Thanks for the info.
I'll try everything mentioned and report back once I have some results.
Old 09-12-2012, 08:22 AM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Originally Posted by jhalphen View Post
All color TVs had SCART by law from 1975 onwards. Only small screen TVs (5") were tolerated to have none.
I think this applies only to sets sold in France... here in Italy the SCART socket wasn't mandatory and many sets were still made without a SCART socket as late as the mid 90s
I think the SCART socket was introduced in 1978 not 1975 anyway...
