Old 09-13-2012, 09:53 AM
miniman82's Avatar
First Light: 1952-2011
Just follow the service literature, it's fairly straightforward. If it's a CTC-4 style setup you remove the neck components, loosen the strap around the CRT boot with the edge purity magnets on it, slide the boot off and the CRT will come right out. If it's coming out of a CTC-5 style shroud where the yoke is part of it, you can leave the yoke in. You should then be able to lift the CRT right out of the mask.
Evolution...
