Old 10-26-2012, 11:31 AM
Originally Posted by ctc17 View Post
Maybe it had an esl dump.
Did you do the setup the way it says in sams under greyscale? Does that end up with the bias to high?
If you have a really strong crt the bias will be all the way down. You really only want to advance the bias once one of the screens is maxed out.
did the grey scale so many times now and it improves nothing. the thing with the drives,rgb i cannot get the rgb lines across the screen unless i raise the bias alittle then i put the service switch back to normal and then i have to lower the bias because its all bloomed. this is the only way to see the color line in the setup, nothing in the sams about bias at least that i remember. the strange thing is i can leave the rgb drives ccw and still have good color.
