Old 10-15-2012, 08:55 PM
You should replace those caps. The white ceramic tube ones, the black ones with yellow lettering too. They're just wax paper caps inside.
Old 10-15-2012, 10:51 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
and remove the spare loose tubes
SR
Old 10-15-2012, 11:21 PM
Originally Posted by radiotron View Post
does anyone have a scamatic, or as sams for this set?
its made out of a 1958 holiday predicta
It looks a lot more like a Princess than a Holiday. The Holiday doesn't use a power transformer.
Can you find a chassis # on it ? Something like 10L43 ?
Old 10-27-2012, 02:58 PM
I believe this is one of the Princess series. These are perhaps rarer than the Predicta sets as we know them. They were too little too late before Philco's demise.
julian
Old 04-05-2013, 01:09 PM
spudz64's Avatar
spudz64 spudz64 is offline
I think I found what model you have....looking at a Philco 1960 product sheet I have, it looks to be the "Fairfield", #4668, using the 10L30 chassis. Compare the measurements from the sheet below to yours and see.
Old 04-05-2013, 02:14 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
thats it thanks!
Looking for zenith cobramatic parts
-johnny the raster master!
Old 04-05-2013, 04:04 PM
decojoe67's Avatar
Interesting set. I've never seen this model in the "Predicta" series. It's true that it doesn't have the desirability of the swivel tube models, but in it's own way it's a nice set. Only recently I've gotten into '50's era TV's and I'm enjoying using them more than my '40's era sets!
Good luck with it.
Old 04-05-2013, 06:07 PM
Technically, I don't think it is in the Predicta series as it has a 90 degree CRT rather than 110.
Old 04-06-2013, 07:18 AM
leadlike's Avatar
leadlike leadlike is offline
Yeah, I don't see anything on the set with the Predicta logo, even the Miss America set has that somewhere on the crt bezel. The Philco logo is the same as you would see on a Predicta Princess, but that is about it. Maybe with the bubble top Philcos selling not at all well, Philco made up some budget sets to use up those extra chassis.
Old 04-06-2013, 01:38 PM
Ex-Philco
The entire '59 TV line was designated as "Predicta". All the '59 swivel tops, and a few low end TVs, used the series string chassis. It was an updated version of the '58 "Seventeener II" box style portable.
For 1960, Philco went to the "cool chassis" design using a power transformer. Early versions used a 5U4, but soon converted to diodes. The layout and circuit design were much improved.
The 1960 logo, knobs and trim are different from the 1959. There were some carry over sets, but for the most part "Predicta" was downplayed after 1960. All bubble tops are Predictas, but not all Predictas are bubble tops. Don
Old 04-06-2013, 03:51 PM
So everything in this Canadian ad can really be called a Predicta, including the "Miss America" and "Slender Seventeener" ?
http://www.rubylane.com/item/137274-...co-PREDICTA-TV
Old 08-01-2025, 10:02 AM
MuzzcoVW's Avatar
MuzzcoVW MuzzcoVW is offline
Craig
That's not a Predicta, but still very cool! Many Philco sets in this era used a Predicta style chassis, same as my 1960 Bristol that I'm just wrapping up an electronic restoration on.
Old 09-12-2025, 05:28 AM
MuzzcoVW's Avatar
Craig
I have a blonde philco predicta 21" meatal cabinet with the speaker built on the side on about foot long legs its a console anybody know what model it is, ive never seen one like it. It worked 2 months ago as you can see.
also why when i turn it on it comes on then the screen slowly goes black? I replaced the 6da4 damper the 6dq6 looks pretty bright thogh could be the 1b3?
IT HAS NOT BEEN NECKED
Any chance you'd sell that set, I'm looking for one. I sent you a PM. Craig
Old 09-15-2025, 12:59 AM
WISCOJIM WISCOJIM is offline
You're responding to a twelve year old post. Radiotron hasn't been here in more than 6 years.
Old 09-19-2025, 05:24 AM
MuzzcoVW's Avatar
Craig
Thanks. I posted that when the server issues started showing up and didn't notice the date. Too bad, that's a set I've been trying to track down for a while
