Old 11-18-2012, 05:02 PM
So, in SW mode, what voltages do you measure on the plates of the tuning cap? I suspect that the short may have damaged a supply resistor, and the FM is more critical if the voltage is now lower...just a WAG!
Old 11-18-2012, 05:59 PM
lnx64's Avatar
lnx64 lnx64 is offline
Ooh good idea. I don't have time tonight to check but I'll check tomorrow. That would make sense since I wasn't even on fm when this happened.
Old 11-20-2012, 03:39 PM
DavGoodlin's Avatar
Motorola Minion
Nice Emud Rundfunkgerat there! I have had three Nordmende with the same tubes you have. The Germans also had a way with getting silky-smooth sound from rather ordinary speakers.
The FM on my Turandot acted similar to yours and replacing the ECC85/6AQ8 fixed it.
Another one was the Elektra, I never did find what killed the FM, so I gave it to a friend whose late Mother always had their Elektra on BC in the kitchen, back when BC had musik.
Old 11-20-2012, 05:13 PM
Didn't those Cherman sets use somethin' funky on detecting FM, something called "Slope Detection" ? So they wouldn't have to use Armstrong's patent, & could use a tube or 2 less ? Somewhere in my Feeble Little Mind, I THINK I remember reading/seeing something about this..But I AM Certificated Crazy, & HAVE Had a Stroke, so don't put too much stock into what I say..(grin)
Old 11-20-2012, 05:24 PM
lnx64's Avatar
Well I've been tracing some voltages, and the V1 tube is not getting any voltage from M4. It's a dud. So I might be looking at a bad cap or something else.
