Old 05-16-2013, 11:13 AM
get it !!!! the worst that could happen is you have a display piece.
do you know a model number or chassis number or have a picture ?
i've worked on two but they were early versions , one wasn't much of a problem a 16" , the other table model had a replaced flyback , i hear this happens a lot and the flybacks aren't good or replaced , it is the 10" mayflower the first porthole if i'm not mistaken , only real issue i had with that one was the horizontal oscillator transformer had an open widing in it , so i had to replace it but couldn't locate a replacement , i then had to adapt a rca type transformer and mount it in the set , works but took a while to figure out.
mike
