Old 06-05-2013, 09:12 PM
The knob layout looks similar to mine. http://www.videokarma.org/showthread.php?t=258006
If you are in a former NTSC standard country your set might even use the same chassis used here in the USA.
I wish mine was that clean when found! If mine were not in a metal cabinet the chassis and CRT would be the only salvageable parts.
Good luck getting it working.
