kvflyer good luck with it , the amount of capacitors is nothing compared to some dumonts and rca sets , beware of mica looking or micamold caps that are really paper/wax type values like .001 , one i missed in my set caused the whole vertical to not work.
Eric where do they sell that stuff ? wont hurt to apply it maybe it will cure it . btw those pics show the set not totaly adjusted as far as vert and horz and the contrast is up all the way , shows that the crt had better days but watchable with a brightner , without it the image slowly gets a little darker and less blacks or if started up from being cooled off its just darker and less blacks. mike |
oh now you can see my test pattern in the picture - the sonar circle in the begining of voyage
mike |
The 10 amp fuse could cause a fire and that would not be a good thing at all. |
Your pictures look keystoned, so you likely have shorted windings in your yoke.
Looks more like perspective effect from the camera angle.
yes odd angles , it is laying on its side and difficult to take pics head on
