#33
From Zeno's post;
"first at 7875 cycles & you will see 2 lines of the pix complete with staircases at apx 1.5 V. This is raw unblanked video sync & all. Next put the generator on blank raster. If the bars have been introduced at that point you will see 10 little bumps, if not nothing but a line between the horz pulses.. Work your way to the right Q203 B, Q203 C, Q204 B, Q204 E, etc until you see them. The pattern will get bigger & be blanked but you will see two lines." Your best bet, starting fresh as you are, is to look at these items as he stated, but your bars will be easier to spot as he said with blank raster however you get it. But pay attention to the stairs, or whatever you have, then go to blank, and you will see the part of the trace that makes up the tv picture, the bars will be in that space. Can you upload that schematic to some free ftp spot and post a link to it, then just delete it after those interested in this thread get a copy....?
Yes you can call me "Squirrel boy" Last edited by Username1; 09-10-2013 at 01:49 PM. |
