Yes run it in normal for the test. The CRT dag usually grounds through a few paths. The DGS shield has fingers on it touching the CRT, usually a spring mounted wire across the bell under the shield, sometimes the ground straps touch the dag. Then usually straps run from the shield to the chassis, tuner assy, & convergence assy. If it were floating you should hear hissing, used to happen to B&W's sometimes. Lead dress keeps me worried here also. Be sure the CRT harness is well away from any HV or large hoz pulses. Focus, yoke, and the 2 HV leads. IIRC its pretty hard for that to happen on this set. Also bad caps may have caused it. Every S cap that opens brings up everything from the HOT on up 10%. In the olden days it usually stressed the divider then the F terminal of CRT socket arcs. If a bunch of them go it starts tossing lightning bolts like you read about ! Quite a show........ So over time things may have been under stress. 73 Zeno
Here are a couple of pics of the CRT and the shroud w/ground leads. You can see the two from the CRT socket and the one that goes from the shroud to the chassis. If you look closely at the left side of the neck you'll see the scratches, but I don't think they went through the coating. They appear more as surface scratches.
As for the setup switch, I'm gong to use some Deoxit on it first to see if it needs a little cleaning. I figure that being in the same position for so many years and the fact it's an open design, it might be dirty/oxidized.
Pioneer SX-1080, Pioneer PL-115D, Pioneer CT-F9191, Pioneer RG-1, Wollensak 8050A, Akai 4000DS MkII, Pioneer CS-05 & Polk 1.2TL Denon 5803A, Pioneer DVL-700, Pioneer CT-W603RS, Toshiba HD-A3, D-Link DSM-520, Dish VIP-722, Polk 1.2TL, CSi5, LS/fx, RT-800 and PSW-650 |
