Old 11-23-2013, 03:33 PM
Have you've checked the brightness control, and the 1M resistor coming off it's center tap? The brightness pot is fed by the same B+ on pin 6 of the 6AS5. The voltage on pin 2 of the CRT should vary from 72-180v(according to Sams) with rotation of that control. Make sure you don't accidentally measure the HV with your VOM.
