Old 12-30-2013, 10:08 AM
antennaweb.org
http://www.antennaweb.org/Stations.a...on=-84.0801613
Edit: in general, there is no substitute for height, so an antenna in the attic may be a good idea. You will have a problem with the PBS station being in the opposite direction from the others, so you will need to experiment.
I picked up a Terk model HDTVA, amplified set-top antenna at a thrift, for three bucks. I'll buy any amplified inside antenna, if it's reasonably priced and in good condition. Then, I compare the performance of same.
The Terk, didn't seem to be that great, but once I set it on the top closet shelf, it made a world of difference. Just four feet higher than the top of the set. Weather changes affect reception, only occasionally, but not on all channels.
My home is 41 miles north of the Milwaukee antenna farm.
