Old 01-09-2014, 04:18 PM
Does yours have a voltage selector switch on it?
Yes, I can select 120, 220, or 240V AC. Though no 100V selection. For the fun of it, I set it to 240VAC and I run it off an outlet like this , similar to Aussie outlets, which I have 240VAC connected to it (a pair of 120VACs, one 180 phase shifted, the usual power company feed in the USA). If you're careful enough, you can modify a 120V parallel plug with a soldering gun, to melt the plastic a little to twist the prongs to angled positions to mate the Aussie style outlet.
I had though of the shortwave bands as a kind of feature list, for owners to brag about "My boombox can get shortwave stations, can yours?".
