Old 02-18-2014, 09:49 PM
bigaudioal's Avatar
High voltages on Admiral 19A11.
Good evening gents,
I have been working on my Admiral 19A11 for some time now. This set has been completely recapped and all resistors replaced. Horizontal sweep transformer and filter choke have also been replaced. The set has been working fairly well, except for a vertical linearity issue (picture squashed at the bottom), which it has always had. I began to test voltages to try and track down this vertical linearity issue. However, I immediately noticed that all voltages were high across the entire set. Even at the 5Y3 tube (L.V, rect.). Pins two and eight should be 240VDC and are running around 266VDC. Pins four, and six should be 240VAC and are running around 292VAC. Any ideas where my issue may lie? My untrained, novice opinion is the power transformer. Nothing in the circuits really before the 5Y3 tube other then the power transformer. The transformer stays cool to the touch for about 40 minutes, then starts to warm up. Never gets too hot to touch, but does get fairly warm.
Any advice would be greatly appreciated. Thanks.
-Al
Old 02-18-2014, 10:36 PM
What's the AC line voltage on the set ? They typical spec out the voltages assuming it's 117, but it's often more like 125 these days. That will increase all the voltages in the set.
Old 02-18-2014, 11:24 PM
bigaudioal's Avatar
SAMS lists it at 117. The ACV at my plug is reading 115.5 right now.
-Al
Old 02-19-2014, 12:21 AM
I always seem to get higher voltages in sets and the ac voltage is 113 to 115 .
your lin issue could be the 6kv caps , what did you put there ? sometimes changing the value a little corrects the lin issue
mike
Old 02-19-2014, 06:48 AM
bigaudioal's Avatar
In photo from left to right the SAMS called for .005, .001, .001, .005, and .005 (all microfarads @ 6KV).
Replacements values are .0047, .001, .001, .0047, and .0047.
Thanks!
Very interesting regarding voltages when AC is 113 to 115. My house typically runs around 115.
-Al
Old 02-19-2014, 08:15 AM
Zenith26kc20's Avatar
Looks like ceramic discs for 6KV caps. They can be non linear. That may be your problem. I did that years ago on my Motorola TS-4 and it worked. One finally failled and the newer tubular 6KV caps perform much better.
Old 02-19-2014, 08:55 AM
bigaudioal's Avatar
Ah! Had no idea about the ceramic discs having possible issues. I will try replacing with tubular ones. Any ones specifically that I should be looking for? Brand? Assuming Mouser carries them.
Thanks again everyone. Guess this is how new guys learn, huh?
-Al
Old 02-19-2014, 10:00 AM
bigaudioal's Avatar
I just did a search on Mouser for 6kV caps and all that came up was ceramic disc type. Any suggestions for where to get the tubular kV caps from?
Thanks.
-Al
Old 02-19-2014, 10:30 AM
I have gotten them from http://justradios.com/ or http://www.alliedelec.com/ .
Phil Nelson
Phil's Old Radios
Old 02-19-2014, 10:47 AM
bigaudioal's Avatar
You guys are great! Going to try using the tubular kV caps and I will report back results.
-Al
Old 02-19-2014, 11:55 AM
Ceramic caps have a peculiar property that causes the capacitance to vary as the voltage on them increases. So when you try to pass a sawtooth waveform through one, it gets "bent" causing the non-linearity.
Old 02-19-2014, 12:01 PM
DavGoodlin's Avatar
Motorola Minion
Thanks Bob, I was wondering why a capacitor that measured correct on my checker would not work well in a signal-coupling or wave-shaping circuit.
Someone else on this forum has suggested that ceramics were good for bypass applications and not much else.
-Dave G
Old 02-19-2014, 12:15 PM
Here's a more in depth discussion on this topic. http://www.videokarma.org/showthread.php?t=260749
When I popped open my National TV-7, I was surprised to see original ceramic doorknob caps for the horizontal. So it seems that ceramics work fine in the horizontal, but not the vertical.
Using a much larger ceramic cap for the vertical should reduce or eliminate the non linearity.
Old 02-19-2014, 01:57 PM
bigaudioal's Avatar
Bob,
Thanks SO much for the explanation. Very interesting and noted. Cannot wait to swap out and see the result. I ordered the caps through Allied.
Thanks again everyone. Will post update in a few days with result.
-Al
Old 02-19-2014, 02:20 PM
N8NM's Avatar
N8NM N8NM is offline
Re: the higher voltages: I've found that it's not unusual for the measured voltages to be a bit higher than those in the Sams (or Rider's) manuals and don't sweat it as long as everything works OK, current draw is reasonable and the transformer stays cool.
