Old 02-20-2014, 09:25 AM
That almost looks like stray magnetic field interference. Did you try moving it around in the room?
What about the adjustments on the yoke cover? I don't remember if they're just for centering. The "T" shaped magnet, on the side of the yoke should have an effect on the pincushioning.
Old 02-20-2014, 10:10 AM
Yeah, that has no effect. This is a rebuilt CRT and the neck is a little crooked which may be throwing things off.
A little. Mostly it effects the horizontal linearity.
Old 02-20-2014, 11:12 AM
OK, I didn't realize you could not only bent the "T" but also twist it.
It's still a little warped in the upper-right, but not too bad I think.
Old 02-21-2014, 09:31 AM
IsthmusTV's Avatar
That looks pretty darn good to me. Seems to have improved the focus, too.
