OK, here is additional information on the 2 Koch Curve fractal geometry fractal antennae pictured in my previous post. The smaller antenna, with the 4 separate elements, may struggle in term of performance in the VHF TV band.
Notice the overall length of the elements from the point of attachment to the end of the elements is not very long. This may limit the low frequency performance of the antenna. The other antenna has a group of smaller self same iterations at the top of the antenna that one might expect to work well on UHF frequencies. However, note that the overall length of these elements is longer than in the other picture. This may improve not only the UHF performance, but the VHF performance. This is just an intuitive observation at this point, as I have neither modeled or measured that particular antenna, but it might be worthy of investigation. |
