The schematic is on Nostalgiaair and shows two 6BE6 tubes.
One is for FM, the other for AM. Try swapping these because one may be failing to ocsillate at FM frequencies. The FM 6BE6 measures 235 volts on the plate, pin 5. You may need one of the Pomona adapters to measure voltage on this tube since it may be hard to reach in the tuner can.
"When resistors increase in value, they're worthless" -Dave G |
