Old 05-04-2014, 06:47 AM
dr.ido's Avatar
dr.ido dr.ido is offline
That's good. Though as you had 5V standby the fuse, standby supply and probably PFC stage are all in the clear. That leaves the main supply to diagnose, though as the set is now working it isn't really worth the effort unless it's for your own curiosity. In which case start looking around the main FETs which I highlighted in the picture above.
